So far it has been tested to work with:
Opera
Mozilla
Mozilla Firefox
Konqueror
IE6 & Sun Java
IE6 & the latest MS JVM
I cant help you if your users are too lazy to change what came with their machines, so don't even bother telling me about their old broken MS JVM that doesn't work. Sorry!
Tested to fail:
Epiphany. This could probably be fixed by configuring the browser though.
The Smileys will take a while to download, and like the Smileys popup the plugin uses a separate thread to do this.
What this means is that you won't see the smileys till they're all downloaded. This does not affect your ability to chat meanwhile.
Remember that more & larger smileys means longer download times for your SmileyPanel.
Please, I'll need some feedback from you people if you want me to fix anything for you.
See the working example at ADnD.com DSmileys preview
Go find it in downloads:-
