New: Updated prefixed PIXX GUI & prefixed SBox GUI
Questions about Thema's mods, & plugins will be answered here
Moderator: Thema
Postby Thema » Mon Mar 19, 2007 12:07 am
Find them in GUI downloads
The SBox GUI has parameters to remove the panels surrounding the source leaving a virtual shoutbox. Plus the ability to choose the nickfield pixx:color index.
Now you can also set prefixed ChanOp nicks and colours.
The Prefixed PIXX GUI now has protected ChanOps for the UnrealIRCD users out there.
Because uploads are broken yet again try this download location:
SBox GUI v3.1b
Prefix-Pixx v3.1b
Any comments, criticisms, praise etc. will be accepted in my plugins forum below.
Please note that these GUIs only work with PJirc 2.2.1
Enjoy
8)
Go on.
Tell me I'm not nice again.
See what it gets you!
Lost or confused?
Read the announcement topic in the
Technical Support forum for help tips.
Thema
A user contributed mod of my mod.
Postby Thema » Mon Mar 19, 2007 6:05 pm
Here you'll find a mod of my mod as modded by AntiAverage.
His idea was to have a single colour and to only highlight the Oper symbol rather then the whole nick. As discussed on page 2 in
viewtopic.php?p=16642#16642
Find the files here:-
Prefixed-PIXX
Prefixed-SBox
Here's a complete sbox update from antiaverage, with not only prefixed nicks but also the ability to position the taskbar to the bottom, top, left, or right:
Sbox v3.2b
Here's the complete pixx update also from antiaverage:
Prefix-Pixx v3.2b
8)
Go on.
Lost or confused?
Thema
new sbox
Postby Astalavista » Mon Mar 19, 2007 8:43 pm
how can i move channel bar to left side?
near nicklist
- Astalavista Baby -
Astalavista
Postby Thema » Mon Mar 19, 2007 10:00 pm
Did you mean to the right, which is where the nicklist is usually?
The channel bar can only be moved to the left or remain beneath the text input.
I think I remember seeing something about the nicklist being able to move to the left also but I wouldn't hold me to that. Also I have no idea what effect it would have on the appearance of the applet if it were done.
8)
Go on.
Lost or confused?
Thema
Postby Thema » Mon Mar 19, 2007 10:14 pm
I just checked back and the parameter I remembered was doing something else not what I thought.
Therefore the answer would be not without more editing of the GUI. :cry:
Sorry
8)
Go on.
Lost or confused?
Thema
Postby Astalavista » Mon Mar 19, 2007 10:19 pm
sorry sorry,
i want to move to right side.
Astalavista
Postby antiaverage » Tue Mar 20, 2007 10:10 am
Astalavista wrote:sorry sorry,
I modified the sbox gui to allow for moving the status bar to the left, right, top, or bottom.
Sbox v3.2b
To have it on the right, make sure you set the parameter:
Code: Select all
<param name="sbox:taskbarside" value="3">
The taskbarwest parameter is not available (deprecated) in this version.
antiaverage
Postby Astalavista » Tue Mar 20, 2007 1:01 pm
run onli left side,
right, top and bottom side not work
This is not work :(
How can i move to right side.
Astalavista
Postby Thema » Tue Mar 20, 2007 2:50 pm
Clear out your java cache. It still has the other version in it.
8)
Go on.
Lost or confused?
Thema
Postby Astalavista » Tue Mar 20, 2007 7:50 pm
i have cleaned the cache and try it one more time but it dont work.
do you have example site address that works
thanks.
Astalavista
Postby antiaverage » Wed Mar 21, 2007 4:22 am
Astalavista wrote:i have cleaned the cache and try it one more time but it dont work.
thanks.
Here you go:
http://theta.in/chat/test/right.html
That was put up with the exact same files as distributed here:
http://bluetain.com/dropspace/sbox_v3.2b.zip
When you clear your cache, it doesn't do to just clear your browser cache. You have to clear your java cache. Look in your taskbar, if you are using Windows, and find the blue coffee cup java icon. Right-click it, hit Open Control Panel, and click Delete Files...
Oh, and that icon won't be there unless you are currently using a Java applet.
antiaverage
Postby Astalavista » Wed Mar 21, 2007 10:54 pm
thank you this is working now.
Astalavista
Re: New: Updated prefixed PIXX GUI & prefixed SBox GUI
Postby Murdock » Fri Jan 08, 2010 11:53 pm
when i undock the channel and then hit the x to dock it again it goes behind the status so i have to undock that and close that to get the channel infront. is this normal behavior or is there some kind of sbox param to change it so the channel goes infront again when you dock it ?
i looked thru faq/readme´s and searched the forum and can´t seem to find the answer so i thought it maybe had something to do with sbox since that´s what i use.
Murdock
Postby Thema » Sun Jan 10, 2010 1:12 am
There isn't a param to change that behaviour.
I don't know if it's just SBox or whether the Pixx GUI has the same bug,
Either way I'm afraid it's a bug that isn't likely to get fixed any too soon, sorry. :(
8)
Go on.
Lost or confused?
Thema
Postby Murdock » Sun Jan 10, 2010 1:33 pm
To bad.. i´ll post it in Bugs since it´s the same for the normal interface. thanks for your answer. ;)
Murdock
Return to Thema's Mods etc.
Who is online
Users browsing this forum: No registered users and 1 guest
