Shrinking, embedding issues?
Questions about Thema's mods, & plugins will be answered here
Moderator: Thema
Postby sabbykat » Thu Mar 12, 2009 3:41 am
Hiya. I've recently found this Mod which is a god-send, i've been trying to find a replacement for my current Shoutbox for quite sometime, especially to merge IRC into it ;)
Now. First question is, i want to make the Display about... 200 Pixel Width, 300-450 Height. I noticed the 'Nick' Bar doesn't shrink as it shrinks, so i'm unsure how to approach this, which might help with my second problem :P
Is it thesible to 'embed' this into an existing Website WITHOUT opening up a new Window?? Example i guess would be how you display a Poll on your Website, no need to go to another Window to vote, it's right there and ready to go!
I hope i can get some help, this is something i've been after forever, And i'm NOT giving up now! >=D
Sabbykat
sabbykat
Re: Shrinking, embedding issues?
Postby Thema » Tue Mar 24, 2009 9:53 am
Nicklist width is settable by parameter as in ther README that came with the download.
readme.txt wrote: nicklistwidth : set the width, in pixel, of the right channels nicklist bar.
------------- Default value is 130.
Example :
<param name="sbox:nicklistwidth" value="130">
As for embedding, yes of course. All you need do is to wrap the applet in a positionable container like a div, table cell, frame, or even an iframe. Or you could use css to position the applet object itself. I recommend using some HTML editor to position some element as suggested above on your page, then drop the applet code into that element.
8)
Go on.
Tell me I'm not nice again.
See what it gets you!
Lost or confused?
Read the announcement topic in the
Technical Support forum for help tips.
Thema
Return to Thema's Mods etc.
Who is online
Users browsing this forum: No registered users and 1 guest
